hi,
Just messing around with an "alienware m11x r1" with 64bit windows7 sp1.
I though I'd try running vdj8 on it, but it fails to initialise (not even a splash screen)
whereas.. the VDJ7.4 pro recently downloaded works perfectly first time!
Am I missing something? The vdj8 was downloaded at roughly 1800hrs UK time (23rd aug).
geposted Sat 23 Aug 14 @ 12:14 pm
I have fixed this now ... I had to edit the BIOS to tell the system that the video is "switchable" rather than discreet.
Annoyingly though, the windows 7 64bit has now decided to disable the nvidia graphics so I now only have the intel graphics loaded.
geposted Sun 24 Aug 14 @ 5:54 am
further to my previous findings it appears that the r1 version of the alienware m11x has an issue with updated nvidia drivers and there is a technical work-around - but I find that I still have to go into device manager and disable the nvidia graphics before virtual dj will work.
geposted Sun 24 Aug 14 @ 7:14 am
