I've just upgraded to VDJ8. I have 2 issues so far.
1) I'm no longer able to split my recording mixes on cross fade. (IT'S JUST ONE CONTINUOUS MIX)
2) On VDJ7 you could hold down the cue button at the start of your mix then right click to make the cue button play continuous. This is no longer the case with VDJ8, once you release the cue button the track stops
Is there an option to overcome these issues as there doesn't seems to be a config option in record like there was on VDJ7
geposted Sun 24 Aug 14 @ 5:50 am
Options -> recordAutoSplit is what you are looking for I think.
geposted Sun 24 Aug 14 @ 6:07 am
Thanks Adion, everything now works perfectly
geposted Mon 25 Aug 14 @ 4:54 am
