Hallo,
first, my config: Audio 2 DJ. Ch1-2 - Master, Ch3-4 - Headphone. - Auto-Headphone on load song active.
On the headphone i only have the PFL, no master, slider on skin 100% on cue side.
Example:
in deck 1 a song is playing (deck 2 on standby). If i activate the sandbox, i hear the sandbox signal more louder, than the normal pfl level.
Want i want: No sandbox signal hearing in the headphone, because i have the deck 1 on pfl to hear about the mix point i use....i want only hear deck 1.
Next:
If sandbox is running, i can not adjust the level of deck 1 with the level sliders in order to adjust the song in die mix signal.
Wenn i moved the slider by playing the sandbox and then i switch the sandbox off, i must move the level slider where it ist standing at the skin to pickup the slider.
Want i want: When sandbox ist running, i can use the level slider to adjust the song in the mix.
Nice greetings, Stefan
Example:
Next:
geposted Wed 27 Aug 14 @ 2:29 am
A new bug i see:
If the deck level slider is to slow (may be <30%), the sandbox can not switch on.
Lg Stefan
Lg Stefan
geposted Wed 27 Aug 14 @ 3:24 am
That is not a bug. The sandbox could only be activated if the volume slider is up and only one deck playing over the master.
It is kind of a bug, that you could still activate the sandbox for deck A if the vol slider of deck B is about 0 - 30% up.
geposted Wed 27 Aug 14 @ 3:37 am
What is the meaning of these programming?
geposted Wed 27 Aug 14 @ 9:24 am
In Options (Show Advanced Options checked), type sandbox in the Search field. You will find a couple of settings useful for the Sandbox functionality.
geposted Wed 27 Aug 14 @ 11:08 pm
My first entry ist with: sandboxPreviewOnly = Yes.
So i think, on active sandbox, i should able to adjust the level from active deck that comes to master signal....
geposted Thu 28 Aug 14 @ 1:52 am
when Sandbox is enabled, then the Master Output (what the audience listens to) cannot be changed, if that is what you ask. This is actually what Sandbox is ...whatever you do is not affecting the Master Output.
geposted Thu 28 Aug 14 @ 3:11 pm
