Cosa devo fare per non vedere l'alone viola nella beatgrid (vedi foto allegata)?
geposted Sun 12 Apr 15 @ 11:06 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the correct language forum: http://www.virtualdj.com/forums/8/Italian_Forum.html
geposted Mon 13 Apr 15 @ 6:42 am
Sorry....
I downloaded and installed the condensed skin regularly. In selecting from options / interface I get a dull purple halo in Beatgrid (see attached photo). How can I solve the problem?
Thanks!
Thanks!
geposted Tue 14 Apr 15 @ 12:45 am
update 13-04-2015 v1.8
fix Rhythmzone Visual for MAC OS
download is avilable
http://www.virtualdj.com/plugins/index.html?addonid=80040
geposted Tue 14 Apr 15 @ 12:57 am
Thanks a Lot! ;-)
I'll try and Than i Will know you.
geposted Tue 14 Apr 15 @ 1:48 am
Perfect. Problem Solved!
Thanks!
Thanks!
geposted Tue 14 Apr 15 @ 7:00 am
THX for Feedback
Have Fun! ;-)
Have Fun! ;-)
geposted Tue 14 Apr 15 @ 9:02 am
>> http://www.virtualdj.com/forums/202030/German_Forum/Automix_wie_gezielt_starten_.html
Where on the skin or how do I recognize, which deck is actually active?
How can i switch/change the active deck or activate a deck/masterdeck? Is there a button for it?
geposted Thu 20 Aug 15 @ 1:42 pm
yes, Klick on 1 or 2 or on the colored Lines to select the MasterDeck ;-)
geposted Thu 20 Aug 15 @ 5:58 pm
Thanks a lot! (Vielen Dank ;-) )
geposted Fri 21 Aug 15 @ 7:31 am
