running virtual dj 8 latest built for the mac side, anyone else notice music distorting while mixing?
i have to play with the gain levels even after reanalyzing (just to be safe) i set it to auto (was on auto+remember)
but when i do critical listening thru monitors i can hear the distortion. quickly turn on vdj 7 same song passages don't distort.
also my sampler has distorted from day one, even when i fiddle with the gain in the sampler editor.
geposted Thu 28 Aug 14 @ 5:25 pm
What is the BPM of the samples when they distort?
Are you trying to play a stock kick sample with a track of ~80 BPM?
geposted Fri 29 Aug 14 @ 3:21 am
Ive tried the kicks samples w all kinds bpm. Its set on sync-lock. The only one that does not distort is kick-snare
geposted Fri 29 Aug 14 @ 9:05 am
https://www.dropbox.com/s/bd3gwraljhalf4e/vdj%20noise.mov?dl=0
proof about 20 sec in you can really hear the noise, at 25 sec its very apparent
geposted Sun 31 Aug 14 @ 3:08 pm
geposted Sun 31 Aug 14 @ 3:09 pm
what version of vdj8 is that i don't see a master VU meter or a limiter indicator?
also i tested and i do not hear distortion with the same stock loops that you are using
i am using windows maybe its different on mac i am not sure but that problem doesn't exist in windows version
geposted Sun 31 Aug 14 @ 5:41 pm
I am using the latest vdj 8 public build. Im on a macbook latest os as well.
geposted Sun 31 Aug 14 @ 5:50 pm
cant edit my post for some reason but heres another sound bite
https://www.dropbox.com/s/8sqk2q7sifxjfel/IMG_9167.MOV?dl=0
geposted Sun 31 Aug 14 @ 8:08 pm
