Cut Slide Logo is my transition of choice but is there a way of slowing any transition down to a similar speed as in VDJ7?
Thanks
Thanks
geposted Fri 05 Sep 14 @ 9:12 am
You could disable the auto crossfader and manually trigger a timed transition.
geposted Fri 05 Sep 14 @ 11:37 am
