Forum: Old versions
Topic: Pioneer DDJ-SZ and VDJ8
Hey there ...is there anybody experiencing this:
The pads on the sz are not lighting up while using VDJ8
This does not occur while using vdj7
geposted Sat 06 Sep 14 @ 4:06 pm
Works fine here.
Keep in mind that the DDJ-SZ has Mac drivers, so make sure you have installed them correctly.
Try a different USB cable (or port)
Read the manual of the DDJ-SZ (UTILITIES), and change the mode to Serato (even if it should work in both modes)
Make sure you run the latest build
geposted Thu 11 Sep 14 @ 8:39 am
everything you mentioned was done.prior to my post , until i finally got it to work proparly by restoring to factory defaults and it works just fine.
geposted Tue 16 Sep 14 @ 9:41 pm
djdad wrote :
Works fine here.
geposted Thu 19 May 16 @ 8:36 pm
