is there any Delay Effect available for VDJ8??I can only find the Echo Effect,but it isn't the same has a Delay FX...
thank you
thank you
geposted Wed 10 Sep 14 @ 9:57 am
just found that the Beatgrid effect is similar to Delay,nice
geposted Wed 10 Sep 14 @ 11:16 am
Echo Effect is the same as Delay, just found the LP and HP knobs (they dont show up on the skin, but do show on the effect sideview window!!!).... SMH....
how do I remove Effects in VDJ8? I dont like at all the WahWah,Distorter,etc... I deleted them from the folder but they still show up!!!
geposted Thu 25 Sep 14 @ 10:33 am
You can't delete native effects, V8 will just keep replacing them, I do wish that you could move them (unwanted effects) to an "ignore" folder
V7's system of external .dlls was better in my opinion (I could tweak stuff and have 2 beatgridFXs in effect on one deck)
geposted Tue 30 Sep 14 @ 9:50 am
