FYI up until this update I have had NO issues, thanks :)
but...
I just opened VDJ8 after a few days of being off it, it saw there was a update which was:
VDJ:BUILD 1957:
- fix timecode drift on relative mode
BUILD 1952:
I downloaded it and when it went to come back up it crashed giving me this apple report error below, now I cannot even get in to get a new update if there is one to fix this...how do I proceed? I do NOT want to uninstall if at all costs
Process: VirtualDJ [512]
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: VirtualDJ [512]
User ID: 501
Date/Time: 2014-09-10 15:28:35.045 -0700
OS Version: Mac OS X 10.10 (14A329r)
Report Version: 11
Anonymous UUID: 386576B5-3A21-CA5F-7B62-316958DCCEC0
Time Awake Since Boot: 110 seconds
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @executable_path/../Frameworks/Breakpad.framework/Versions/A/Breakpad
Referenced from: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Reason: no suitable image found. Did find:
/Applications/VirtualDJ 8.app/Contents/MacOS/../Frameworks/Breakpad.framework/Versions/A/Breakpad: code signature invalid for '/Applications/VirtualDJ 8.app/Contents/MacOS/../Frameworks/Breakpad.framework/Versions/A/Breakpad'
Binary Images:
0x7fff6889d000 - 0x7fff688d3837 dyld (353.2.1) <4696A982-1500-34EC-9777-1EF7A03E2659> /usr/lib/dyld
Model: MacBookAir4,2, BootROM MBA41.0077.B11, 2 processors, Intel Core i5, 1.7 GHz, 4 GB, SMC 1.73f66
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333235533642465238432D48392020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333235533642465238432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xE9), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.3.0b13 14661, 3 services, 17 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM256C, 251 GB
USB Device: FaceTime Camera (Built-in)
USB Device: Hub
USB Device: USB2.0 Hub
USB Device: My Passport 0741
USB Device: USB Receiver
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: Internal Memory Card Reader
Thunderbolt Bus: MacBook Air, Apple Inc., 8.1
but...
VDJ:BUILD 1957:
BUILD 1952:
Version: ???
User ID: 501
Report Version: 11
Crashed Thread: 0
Dyld Error Message:
Binary Images:
USB Device: Hub
USB Device: Hub
geposted Wed 10 Sep 14 @ 5:39 pm
Got the same on a MacBook Pro
Process: VirtualDJ [699]
Version: ???
Parent Process: launchd [155]
Responsible: VirtualDJ [699]
User ID: 501
Date/Time: 2014-09-10 19:05:22.577 -0400
OS Version: Mac OS X 10.9.4 (13E28)
Report Version: 11
Anonymous UUID: 79BC5333-B02E-0F98-9314-9DE01652165C
Crashed Thread: 0
Dyld Error Message:
Library not loaded: @executable_path/../Frameworks/Breakpad.framework/Resources/breakpadUtilities.dylib
Referenced from: /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
Reason: image not found
Binary Images:
0x7fff62de7000 - 0x7fff62e1a817 dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
0x7fff85b16000 - 0x7fff85b1bfff libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib
0x7fff85b1c000 - 0x7fff85b24fff libsystem_dnssd.dylib (522.92.1) <17B03FFD-92C5-3282-9981-EBB28B456207> /usr/lib/system/libsystem_dnssd.dylib
0x7fff870e5000 - 0x7fff8716efff com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8716f000 - 0x7fff87170ff7 libSystem.B.dylib (1197.1.1) <E303F2F8-A8CF-3DF3-84B3-F2D0EE41CCF6> /usr/lib/libSystem.B.dylib
0x7fff87171000 - 0x7fff87172fff libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib
0x7fff87173000 - 0x7fff87279ff7 com.apple.ImageIO.framework (3.3.0 - 1043) <C4ADE5B1-A540-34E1-A043-118185489C9D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8727a000 - 0x7fff8727affd com.apple.audio.units.AudioUnit (1.10 - 1.10) <68B21135-55A6-3563-A3D6-3E692A7DEB7F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8727b000 - 0x7fff876c9fef com.apple.VideoToolbox (1.0 - 1273.54) <4699BB55-7387-3981-9217-869215F00CA9> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff8772b000 - 0x7fff8804b32b com.apple.CoreGraphics (1.600.0 - 599.25.10.1) <EC14B831-96BB-3A50-A451-E36BDC8F59FB> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff88051000 - 0x7fff88051fff com.apple.Carbon (154 - 157) <4E260C09-78F4-305B-B408-13321CAF6213> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff88194000 - 0x7fff88341f27 libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
0x7fff88342000 - 0x7fff88342fff com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff88343000 - 0x7fff883a8ffb com.apple.Heimdal (4.0 - 2.0) <F34D6627-9F80-3823-8B57-DB629307DF87> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff88417000 - 0x7fff88446fd2 libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib
0x7fff88447000 - 0x7fff88456ff8 com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff8853c000 - 0x7fff88561ff7 com.apple.CoreVideo (1.8 - 117.2) <4674339E-26D0-35FA-9958-422832B39B12> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff885e4000 - 0x7fff885ffff7 libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib
0x7fff88600000 - 0x7fff88647fff libFontRegistry.dylib (127) <A77A0480-AA5D-3CC8-8B68-69985CD546DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff88779000 - 0x7fff88779fff com.apple.Cocoa (6.8 - 20) <E90E99D7-A425-3301-A025-D9E0CD11918E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8877a000 - 0x7fff887cbff7 com.apple.audio.CoreAudio (4.2.1 - 4.2.1) <BE13E840-FB45-3BC2-BCF5-031629754FD5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff887d4000 - 0x7fff887ebff7 com.apple.CFOpenDirectory (10.9 - 173.90.1) <EBC0A1F2-9054-3D39-99AE-A3F655E55D6A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff887ec000 - 0x7fff887edfff libsystem_sandbox.dylib (278.11.1) <0D0B13EA-6B7A-3AC8-BE60-B548543BEB77> /usr/lib/system/libsystem_sandbox.dylib
0x7fff88bde000 - 0x7fff88bf8fff libdispatch.dylib (339.92.1) <C4E4A18D-3C3B-3C9C-8709-A4270D998DE7> /usr/lib/system/libdispatch.dylib
0x7fff88bf9000 - 0x7fff88c00fff libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib
0x7fff88c01000 - 0x7fff88c5cffb com.apple.AE (665.5 - 665.5) <BBA230F9-144C-3CAB-A77A-0621719244CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff88cc8000 - 0x7fff88d15fff com.apple.AppleVAFramework (5.0.27 - 5.0.27) <608D91BD-9D88-3FAB-9A06-24C1DAEA092D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff88d51000 - 0x7fff88d52fff liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
0x7fff8971b000 - 0x7fff8971bfff com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8971c000 - 0x7fff89728ff7 com.apple.OpenDirectory (10.9 - 173.90.1) <256C265B-7FA6-326D-9F60-18DADF5F3A0E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff89745000 - 0x7fff89779fff libssl.0.9.8.dylib (50) <B15F967C-B002-36C2-9621-3456D8509F50> /usr/lib/libssl.0.9.8.dylib
0x7fff89864000 - 0x7fff8988dff7 libc++abi.dylib (49.1) <21A807D3-6732-3455-B77F-743E9F916DF0> /usr/lib/libc++abi.dylib
0x7fff89895000 - 0x7fff8989efff com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <383FB557-E88E-3239-82B8-15F9F885B702> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff8989f000 - 0x7fff898b0ff7 libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib
0x7fff89b5c000 - 0x7fff89b77ff7 libPng.dylib (1043) <23D2DAB7-C9A9-392F-989A-871E89E7751D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff89ef7000 - 0x7fff89f07fff libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
0x7fff89f2d000 - 0x7fff89f7bfff libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
0x7fff8a056000 - 0x7fff8a13dff7 libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
0x7fff8a13e000 - 0x7fff8a142fff libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib
0x7fff8a3cd000 - 0x7fff8a3d8ff7 com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8a43b000 - 0x7fff8a43fff7 libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib
0x7fff8a440000 - 0x7fff8a50afff com.apple.LaunchServices (572.28 - 572.28) <FDED4724-4CB6-3DE5-B785-AE6D4C261CF6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8a50b000 - 0x7fff8a515fff libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib
0x7fff8a545000 - 0x7fff8b0bbff7 com.apple.AppKit (6.9 - 1265.21) <9DC13B27-841D-3839-93B2-3EDE66157BDE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8b0bc000 - 0x7fff8b0bdfff com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff8b341000 - 0x7fff8b38afff com.apple.CoreMedia (1.0 - 1273.54) <CAB7303A-9AB2-317A-99C3-BEAA8AE8764B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff8b38b000 - 0x7fff8b5e5ff9 com.apple.security (7.0 - 55471.14.8) <EA03E140-2509-3A07-8440-2DC97C0D478B> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8b5e6000 - 0x7fff8b5e7ff7 libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8b5e8000 - 0x7fff8b5efffb libcopyfile.dylib (103.92.1) <CF29DFF6-0589-3590-834C-82E2316612E8> /usr/lib/system/libcopyfile.dylib
0x7fff8b8e2000 - 0x7fff8b8e8ff7 libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib
0x7fff8b914000 - 0x7fff8b980fff com.apple.framework.IOKit (2.0.1 - 907.100.13) <057FDBA3-56D6-3903-8C0B-849214BF1985> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8b981000 - 0x7fff8bb39ffb libicucore.A.dylib (511.34) <616A65D6-3F20-3EAB-8CA8-273AD890261C> /usr/lib/libicucore.A.dylib
0x7fff8bd10000 - 0x7fff8bd3fff9 com.apple.GSS (4.0 - 2.0) <44E914BE-B0D0-3E05-9451-CA9E539AFA52> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff8bd59000 - 0x7fff8bdbdfff com.apple.datadetectorscore (5.0 - 354.5) <0AE9749A-6BFC-3032-B802-210DF59AEDB0> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8bde2000 - 0x7fff8bdefff7 libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
0x7fff8bdf0000 - 0x7fff8be37ff7 libcups.2.dylib (372.4) <36EA4350-43B4-3A5C-9904-10685BFDA7D4> /usr/lib/libcups.2.dylib
0x7fff8c306000 - 0x7fff8c308ff7 libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib
0x7fff8c31c000 - 0x7fff8c31cffd libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
0x7fff8c344000 - 0x7fff8c382ff7 libGLImage.dylib (9.6.1) <5E02B38C-9F36-39BE-8746-724F0D8BBFC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff8c72f000 - 0x7fff8c733ff7 libheimdal-asn1.dylib (323.92.1) <CAE21FFF-5763-399C-B7C5-EEBFFEEF2242> /usr/lib/libheimdal-asn1.dylib
0x7fff8ca58000 - 0x7fff8ca61ffd com.apple.CommonAuth (4.0 - 2.0) <32BA436F-6319-3A0B-B5D2-2EB75FF36B5B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff8ccab000 - 0x7fff8cdffff3 com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <69B273E8-5A8E-3FC7-B807-C16B657662FE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff8d7c4000 - 0x7fff8d7d5ff7 libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib
0x7fff8d897000 - 0x7fff8d8e4ff2 com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8d9f9000 - 0x7fff8dcf7fff com.apple.Foundation (6.9 - 1056.13) <2EE9AB07-3EA0-37D3-B407-4A520F2CB497> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff8de66000 - 0x7fff8debffff libTIFF.dylib (1043) <D7CAE68F-6087-3B40-9CB8-EC6DB47BF877> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8dec0000 - 0x7fff8df2dfff com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8e23a000 - 0x7fff8e3d5ff8 com.apple.CFNetwork (673.3 - 673.3) <4375B7CB-34B6-3A26-99AC-2D2404AD9C9B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8e3d6000 - 0x7fff8e3e4fff com.apple.opengl (9.6.1 - 9.6.1) <B22FA400-5824-36AF-9945-5FEC31995A0E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8e6fd000 - 0x7fff8e81ffff com.apple.avfoundation (2.0 - 651.12.1) <FF001F98-E198-3B1D-A7EB-A8C48E6E34A3> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff8e820000 - 0x7fff8e82bfff libGL.dylib (9.6.1) <4B65BF9F-F34A-3CD1-94E8-DB26DAA0A59D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8e82c000 - 0x7fff8e91dff9 libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib
0x7fff8ecfa000 - 0x7fff8ed21ff7 libsystem_network.dylib (241.3) <8B1E1F1D-A5CC-3BAE-8B1E-ABC84337A364> /usr/lib/system/libsystem_network.dylib
0x7fff8ed22000 - 0x7fff8ee58ffd com.apple.WebKit (9537 - 9537.77.4) <A0291E16-4ED9-30E8-B9A2-DB836778EE9E> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8ee59000 - 0x7fff8ee5cffc com.apple.IOSurface (91.1 - 91.1) <D00EEB0C-8AA8-3986-90C1-C97B2486E8FA> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff8ee5d000 - 0x7fff8ee68fff libkxld.dylib (2422.110.17) <B6140BAB-0EAF-3E4F-B055-314068056BB4> /usr/lib/system/libkxld.dylib
0x7fff8eef7000 - 0x7fff8eef9ff3 libsystem_configuration.dylib (596.15) <4998CB6A-9D54-390A-9F57-5D1AC53C135C> /usr/lib/system/libsystem_configuration.dylib
0x7fff8ef14000 - 0x7fff8ef14fff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8ef15000 - 0x7fff8ef30ff7 libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
0x7fff8ef31000 - 0x7fff8ef34fff libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8f1b7000 - 0x7fff8f1beff8 liblaunch.dylib (842.92.1) <A40A0C7B-3216-39B4-8AE0-B5D3BAF1DA8A> /usr/lib/system/liblaunch.dylib
0x7fff8f1d6000 - 0x7fff8f298ff5 com.apple.CoreText (367.20 - 367.20) <B80D086D-93A9-3C35-860E-9C3FDD027F3B> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8f299000 - 0x7fff8f29dff7 libGIF.dylib (1043) <AF0FE71A-27AB-31E0-8CEA-BC0BF2091FA8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff8f4fd000 - 0x7fff8f54ffff libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib
0x7fff8f642000 - 0x7fff8f645fff com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff8fc82000 - 0x7fff8fcc1fff libGLU.dylib (9.6.1) <AE032555-3E2F-3DBF-A26D-EA4576061605> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8fccf000 - 0x7fff900b0ffe libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff90153000 - 0x7fff9017bffb libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
0x7fff9017c000 - 0x7fff9017efff libCVMSPluginSupport.dylib (9.6.1) <FB37F4C4-1E84-3349-BB03-92CA0A5F6837> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff90518000 - 0x7fff905f7fff libcrypto.0.9.8.dylib (50) <B95B9DBA-39D3-3EEF-AF43-44608B28894E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff905f8000 - 0x7fff90605ff0 libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
0x7fff90658000 - 0x7fff90674ff7 libsystem_kernel.dylib (2422.110.17) <873931CE-D1AF-3596-AADB-D2E63C9AB29F> /usr/lib/system/libsystem_kernel.dylib
0x7fff90675000 - 0x7fff90677fff libRadiance.dylib (1043) <9813995C-DEAA-3992-8DF8-320E4E4E288B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff906ba000 - 0x7fff9089ffff com.apple.CoreFoundation (6.9 - 855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff908a0000 - 0x7fff9098afff libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib
0x7fff9098b000 - 0x7fff90a56fff libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff90a57000 - 0x7fff90acafff com.apple.securityfoundation (6.0 - 55122.3) <8575DF7A-EC79-3FCE-A737-7512363A5B12> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff90b94000 - 0x7fff90d02ff7 libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff90d1c000 - 0x7fff90d1cfff com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff90d1d000 - 0x7fff90d44ffb libsystem_info.dylib (449.1.3) <7D41A156-D285-3849-A2C3-C04ADE797D98> /usr/lib/system/libsystem_info.dylib
0x7fff90d45000 - 0x7fff90db4ff1 com.apple.ApplicationServices.ATS (360 - 363.3) <546E89D9-2AE7-3111-B2B8-2366650D22F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff90db8000 - 0x7fff90e2ffff com.apple.CoreServices.OSServices (600.4 - 600.4) <C63562F5-6DF5-3EE9-8897-FF61A44C8251> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff91040000 - 0x7fff910a3ffb com.apple.SystemConfiguration (1.13.1 - 1.13.1) <2C8E1A73-5AD6-3A7D-8ED8-D6755555A993> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff910a4000 - 0x7fff910a9fff com.apple.DiskArbitration (2.6 - 2.6) <A4165553-770E-3D27-B217-01FC1F852B87> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff9173c000 - 0x7fff917ecff7 libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff917ed000 - 0x7fff917f7ff7 com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff91b6b000 - 0x7fff91e55fff com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff91e56000 - 0x7fff91e72fff libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib
0x7fff91e73000 - 0x7fff91eb8ff6 com.apple.HIServices (1.23 - 468) <5970AF5C-F5BD-3B6A-97C9-95B2CA98D71D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff91fb0000 - 0x7fff91fb5ff7 libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib
0x7fff91fb6000 - 0x7fff91fb7ffb libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib
0x7fff91fb8000 - 0x7fff91fe1fff com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff91fe7000 - 0x7fff91feaff7 libdyld.dylib (239.4) <7C9EC3B7-DDE3-33FF-953F-4067C743951D> /usr/lib/system/libdyld.dylib
0x7fff9211f000 - 0x7fff923f3fc7 com.apple.vImage (7.0 - 7.0) <D241DBFA-AC49-31E2-893D-EAAC31890C90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff924c2000 - 0x7fff924c9ff7 libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
0x7fff924ca000 - 0x7fff9250cff7 libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
0x7fff9294c000 - 0x7fff9294dff7 libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
0x7fff92971000 - 0x7fff92995fff libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib
0x7fff92996000 - 0x7fff929cfff7 com.apple.QD (3.50 - 298) <C1F20764-DEF0-34CF-B3AB-AB5480D64E66> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff92a3e000 - 0x7fff92a47ff3 libsystem_notify.dylib (121) <52571EC3-6894-37E4-946E-064B021ED44E> /usr/lib/system/libsystem_notify.dylib
0x7fff92b4b000 - 0x7fff92b53ffc libGFXShared.dylib (9.6.1) <25BBF325-AC57-3BAA-9427-2D14CC243AE6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff92ba1000 - 0x7fff92c31ff7 com.apple.Metadata (10.7.0 - 800.28) <E85AEB1B-CB17-38BC-B5C6-AAB50B47AF05> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff92c32000 - 0x7fff92c36ff7 libsystem_stats.dylib (93.90.3) <4E51D5B0-92A0-3D0D-B90E-495A1ED3E391> /usr/lib/system/libsystem_stats.dylib
0x7fff92c37000 - 0x7fff92d26fff libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff92d31000 - 0x7fff92d55ff7 libJPEG.dylib (1043) <25723F3F-48A6-3AC5-A7A3-58E418FEBF3F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff92d56000 - 0x7fff92ddfff7 libsystem_c.dylib (997.90.3) <6FD3A400-4BB2-3B95-B90C-BE6E9D0D78FA> /usr/lib/system/libsystem_c.dylib
0x7fff92ead000 - 0x7fff92f9bfff libJP2.dylib (1043) <C4031D64-6C57-3FB4-9D87-874D387381DB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff9326a000 - 0x7fff932affff libcurl.4.dylib (78.94.1) <88F27F9B-052E-3375-938D-2603E90D8AD5> /usr/lib/libcurl.4.dylib
0x7fff932eb000 - 0x7fff932ebff7 libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib
0x7fff9352d000 - 0x7fff93546ff7 com.apple.Kerberos (3.0 - 1) <F108AFEB-198A-3BAF-BCA5-9DFCE55EFF92> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff93635000 - 0x7fff9363cfff com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
Model: MacBookPro9,2, BootROM MBP91.00D3.B09, 2 processors, Intel Core i7, 2.9 GHz, 8 GB, SMC 2.2f44
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.6f1 14216, 3 services, 15 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS541075A9E662, 750.16 GB
Serial ATA Device: MATSHITADVD-R UJ-8A8
USB Device: Backup+ Desk
USB Device: Hub
USB Device: Hub
USB Device: IR Receiver
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
Version: ???
User ID: 501
Report Version: 11
Crashed Thread: 0
Dyld Error Message:
Binary Images:
USB Device: Hub
USB Device: Hub
USB Device: Hub
geposted Wed 10 Sep 14 @ 6:01 pm
Known issue with macs this build
Download this and replace the exe (or whatever they call in with macs)
http://virtualdj.com/download/virtualdj8/mac/1949/zip
geposted Wed 10 Sep 14 @ 7:28 pm
That should be fixed now
geposted Wed 10 Sep 14 @ 10:08 pm
In a new update?? if so whats the number?
geposted Wed 10 Sep 14 @ 10:12 pm
1957, it must have been something really simple
geposted Wed 10 Sep 14 @ 10:14 pm
If you look at my opening post that number is the one that caused this issue.
geposted Wed 10 Sep 14 @ 10:30 pm
must be re updated. or installed manually
geposted Wed 10 Sep 14 @ 10:44 pm
Same thing happened on my windows 7 pc, so i don't think it's mac specific. I uninstalled and then reinstalled and the same issue. It opens down in the task bar but the program does not open. I uninstalled again, and installed an earlier build of vdj8, build 1745 is what i had in my downloads folder and now it opens just fine. I will wait for the next update i suppose. Ok i updated to build 1948 on pc and all is fine now.
geposted Thu 11 Sep 14 @ 1:22 pm
