Hi,
I think there is a (functionality-related) bug here:
1. On Numark's Mixtrack Quad, make sure you're in "Scratch Mode"#
2. Give a forward push to the top of the jog wheel, it will do a forward scratch and slow down till the music temporarily stops, then it will start spinning again as if it was manually stopped.
I think this is inconsistent with an analogue deck's behavior. I would expect the forward scratch to slow down till it reaches the nominal rotation speed of the deck (taking into consideration the current pitch setting), i.e. continue playing back the music without a temporary stop. Or is this not right?
Is this something configurable or does it require a software fix?
Keep up the good work!!!
Many thanks and regards,
Nikos
Nikos
geposted Sat 13 Sep 14 @ 1:04 pm
