I am new to using the controller and virtual dj8, I bought my license to use my controller, and I don't own any speakers, so I wanted to use my laptop speakers for playing the music out loud and my headphones pre listening to the next track I want to play. However I cant seem to make that work with the software or hardware or the sound card that comes in the pioneer ddj sb. If someone could point me in the right direction that would be great, Many thanks.
geposted Wed 17 Sep 14 @ 10:05 am
Assuming that you use VirtualDj 8, open config, click on "Audio" icon on the left and then finally select these buttons:
Speakers + Headphones, 2 Soundcards
On the soundcard selection undernieth , select your laptop's soundcard as "Master", CH1+2, and Pioneer DDJ-SB(WASAPI) as "Headphones"
On Headphones please make sure you select CH3+4
Hit apply, and you should be done!
geposted Wed 17 Sep 14 @ 10:37 am
THanks, I have done that, and now I can here both decks playing both through my laptop and through my headphones, should that happen?
geposted Wed 17 Sep 14 @ 10:47 am
Sorry I have sorted it all now, thanks for your help!
geposted Wed 17 Sep 14 @ 10:51 am
