I often find out that CGB is misaligned. I was wondering how to fix that with MIDI controller (Mixtrack Pro)? I'd just use PITCH BEND buttons for that case, they are the most obsolete. Could you help me out with mapping/scripting?
Thanks!
Thanks!
geposted Fri 19 Sep 14 @ 3:52 pm
Very possible but without you proving your licence to use hardware it could be read as you using pirated software.
Connect your serial to your user account and I'd be happy to help.
geposted Fri 19 Sep 14 @ 4:11 pm
fine adjustment of the CBG can be done with a controller using an endless encoder, or the jogwheel.
Map a button as ..
set 'cbgmove' 1 while_pressed
and then map an encoder as ..
var 'cbgmove' ? adjust_cbg : whateveractionitalreadyhas
or the touchwheel/jogwheel
var 'cbgmove' ? adjust_cbg : touchwheel
Custom mapping is only available in Pro Infinity version.
Map a button as ..
geposted Fri 19 Sep 14 @ 4:54 pm
I only have legit LE version for live gigs, but I tested that in PRO version and it works perfectly fine, thank you! I've been already thinking about switching to Traktor because I didn't really know that custom mappings can be so advanced. Since I still have one pitch button bend left, do you have any ideas what I could use it for? Maybe for BPM adjustment or anything else that could be useful? I'm really out of ideas, but I'm sure that there are a lot of useful combinations which make DJ-ing easier and more fun.
geposted Fri 19 Sep 14 @ 5:13 pm
