Discussion about Mix Lab VDJ 8
geposted Fri 19 Sep 14 @ 3:59 pm
Thank you for this skin.
On Mac the waveform doesn't appear
geposted Sat 20 Sep 14 @ 11:22 am
Which waveform? The songpos waves on each deck, or the large overhead rhythmzone waves?
When you say "doesn't appear", what do you see? Nothing at all (blank) or a block of colour?
Do you get this issue with other skins?
I do not have a Mac to test on BTW.
geposted Sat 20 Sep 14 @ 11:33 am
1920x1200 wold be nice
geposted Sun 21 Sep 14 @ 1:26 pm
Just maximize it. :-)
The graphics were designed for the original res by DJ Format. I don't have access to any higher res versions.
geposted Sun 21 Sep 14 @ 3:02 pm
yeah the top waveform where it scrolls through doesn't show. it's just solid blue and solid red. the waveform on the deck itself loads fine. on mac.
![](/image/37334/147963/Screen Shot 2014-10-06 at 1.15.20 PM.png)
geposted Mon 06 Oct 14 @ 3:15 pm
Unfortunately this is a Mac only issue. Some aspects of VDJ 8 are broken in the Mac version.
Atomix know this, and yet the issues remain.
This particular problem is caused by the Mac version requiring the <rhythmzone> code rather than working with the older <rhythm> code as the PC version does.
There's a transparency issue as well which affects some skins.
I don't use Macs so I can only check that things work on PC.
geposted Mon 06 Oct 14 @ 4:45 pm
so no idea how to fix it? if there's anything you want me to test on the mac for you let me know.
geposted Tue 07 Oct 14 @ 12:13 am
I know how to fix it. As I said, it requires the <rhythm> code to be changed to <rhythmzone>
[later] I have re-coded that section, so now hopefully it will work on Mac.
It's uploaded but you'll have to wait for it to be made available. It's v1.2
geposted Tue 07 Oct 14 @ 4:52 am
Update:
v 1.3 adds clickable transitions to the video screens
geposted Sun 12 Oct 14 @ 5:46 am
Oops!
There was an error with the code in v1.3 where the video transition button added to the video screens was "showing through" the deck panels.
Now corrected in v1.4
geposted Mon 13 Oct 14 @ 11:50 am
v1.5 fixes CPU meter not working.
geposted Tue 14 Oct 14 @ 5:03 am
I'm not able to download it :(
geposted Mon 10 Nov 14 @ 5:05 am
Sorry, but this skin is not available to Home FREE users.
The majority of skins and other add-ons are only available to registered licensed users and are one of the many benefits of purchasing a license for the software.
Some VirtualDJ v8 add-ons such as selected skins and samples are available to home users though. To see what's available, please go to our add-ons page for VirtualDJ v8. Those without a green LE/PLUS/PRO tag are free to download. If you would like to download all add-ons without any limitations, you will need to purchase a license.
geposted Mon 10 Nov 14 @ 5:21 am
Please VDJ Home version, excellent skin
geposted Sat 06 Dec 14 @ 4:31 pm
how do you record? I cant find a rec button
geposted Mon 27 Apr 15 @ 12:04 pm
Please read your VDJ 8 User's Guide - page 87.
geposted Mon 27 Apr 15 @ 12:31 pm
Downloaded this on Mac for the crossfader for low mids and highs. However, bassfader eq does not work at all. Any ideas about why this would happen?
geposted Mon 11 May 15 @ 12:53 am
Sorry but it works fine on my PC and I don't have a Mac.
The skin script/code is cross platform, so if it works on PC it should therefore work on Mac - unless there is an issue with VDJ on the Mac.
geposted Mon 11 May 15 @ 4:16 pm
why i cant download it?
geposted Wed 20 May 15 @ 3:59 pm
