Forum: Addons
Addons comments
Topic: Mix Lab VDJ 8 - Page: 4
McDoc71PRO InfinityMember since 2017
NoRRieRoos wrote :
I would like to know how i config my pitch to not have a so fast changing of bpm
I think we're asking the same question but no one has yet figured out exactly what we're asking.
Specifically on the MixLab skin - beside the pitch / tempo slider - there are 3 side buttons for "bumping" the tempo slightly. It acts differently than the "+/-" bend buttons because these "bumps" adjust the tempo permanently.
On my VDJ 6 setup with Mixlab - it took 2 bumps to go one 1BPM.
I have a Brand New Laptop where I loaded up VDJ 8 - but the bumps go up about 5BPM - so I CAN'T USE THIS NEW LAPTOP to DJ until I find the answer on how to adjust the "bump" back down to 1/2 a bpm . . . .
Trying to figure out how to adjust the BPM "bump" buttons. I know they are in the MixLab3 skin - not sure if they are in other skins.
I'm not talking about the temporary +/- "bend" at the bottom of the BPM slider . . . but rather on my MixLab skin - there are 3 small buttons off to the side of the BPM slider where the middle one brings the track slowly back to its natural BPM and is labeled "BPM Reset" - but the top or bottom "bump" the tempo slightly into a permanent new BPM to edge it up or down slightly.
Well - slightly is the problem . . . in my older version of VDJ (6) it would "bump" the tempo up or down by 1/2 a beat . . . but in VDJ8 - it moves it like 5 bpm at a time. I want to figure out how to set the value of the "bump" to a much smaller %.
Thank you in Advance for your help.
geposted Sun 11 Nov 18 @ 6:54 am
I've just had a quick look at this for you...
The original skin code was: <button action="pitch" value="-3" chan="1">
The updated code is: <button action="pitch -3" deck="1">
....so you can see that nothing has been changed, as far as the value goes.
However, there does appear to be a different effect on the pitch between the two versions (original skin and updated skin) when run on VDJ 8. Obviously this is not down to the skin or the code in the skin, but in the way VDJ 8 interprets the code (old vs new).
Quote :
That would depend entirely on the BPM of the track and the pitch range you've set.
Quote :
Again, that amount is dependent on track BPM and pitch range.
Anyway, you will need to experiment with adjusting the value in the lines of code on those buttons (see above).
There are four lines in total. One for each button - left deck up/down and right deck up/down. According to the VDJScript wiki, you can specify an exact BPM value if you want. Changing from <button action="pitch -3" deck="1"> to <button action="pitch -0.5 bpm" deck="1"> etc. would do what you're asking.
geposted Sun 11 Nov 18 @ 2:37 pm
Quote :
Quote :
Thank you for the reply . . . how can I change the value? I'm not seeing the option to do so inside the "Config" settings . . . and I'm honestly not sure how that button is labeled to begin with.
Much appreciated !
geposted Sun 11 Nov 18 @ 11:59 pm
You need to edit the skin XML file with a text editor.
geposted Mon 12 Nov 18 @ 12:29 am
I am trying to play a video - and now for the first time - on my extended video display - the name of the file along with a moving record image is displayed during playback.
How do I disable the file information and the record action image from the video playback?
I just want the RAW video image - nothing else displayed.
Thank you in advance for your help on this
geposted Thu 15 Nov 18 @ 10:09 am
Options, interface
Video skin: None
geposted Thu 15 Nov 18 @ 1:33 pm
SablalaHome userMember since 2018
How to download mixlab skins
geposted Thu 07 Feb 19 @ 4:59 pm
Buy a license.
geposted Thu 07 Feb 19 @ 5:18 pm
Seite : [<<] [<]
