Hey guys, is there a specific size that is best for the personal logo in VDJ8, also please can anyone advise on file type, I tried a .png but it displayed in a sort of "repeated" format in various sizes at the bottom... thanks in advance!
geposted Sun 21 Sep 14 @ 4:33 am
jpeg should work also find.
I recommend also the plugin from SBDJ
http://www.virtualdj.com/plugins/index.html?category=new&search=show
geposted Sun 21 Sep 14 @ 7:20 am
Thanks RobRoy, will give it a try..
geposted Sun 21 Sep 14 @ 9:02 am
I was just searching this topic and noticed that no one answered the OP's original question, what size should a custom logo be? I realize the plugin mentioned above can be used but I'd rather just take advantage of the built in logo option within VDJ 8. I assume the file format should be PNG so the logo can be on a transparent background but what size should it be? I guess I could search for the default VDJ logo file and base my logo size off that but I thought I'd ask here instead. Others might find this info useful also.
Someone mentioned that JPG files can be used but I assume that is for square or rectangular logos only? What about if you have a circle or odd shaped logo? Then doesn't a PNG on transparent background need to be used?
geposted Thu 16 Mar 17 @ 11:41 pm
For any shape other than rectangular, png format is necessary and of course when any transparency needs to be offered.
For the size, you will need to know the size of the Output monitor, and arrange its size accordingly.
But i would strongly advise to disable the logo from Settings and use the Showlogo Plugin which gives you way more options
geposted Thu 16 Mar 17 @ 11:48 pm
I tried ShowLogo and although it took me awhile to figure out how to add my logo and adjust the settings it seems to be working well. Thanks!
geposted Wed 22 Mar 17 @ 12:24 am
