I have noticed that when downloading a track from Content Unlimited to the cache, if the download fails maybe due to a dodgy tethered 3G connection which is usually my case, VDJ8 will either hang, restart or freeze. I've reproduced this bug 3 or 4 times now. Luckily the last time during a wedding reception VDJ restarted quickly so I was able to continue on without any major disruption.
This is running on Windows 8.1.
geposted Mon 22 Sep 14 @ 4:03 am
I've noticed the same issue.. if I try to play several songs from content unlimited (or just check the quality) VDJ graphical interface stop responding.. I can use the midi controller however CPUis on 100% and graphic is frozen. If I keep it running for a minute pc is hangig as well.. so I have to close the app asap and start it again. I have suspicion that it's somehow related to the running "analysis" of the current track. Tested on Windows 7 and Mac os X with same result.
geposted Tue 23 Sep 14 @ 5:22 am
Same thing has happened to me a few times. Makes me very nervous to use CU during a live show... Which kind of decreases it's value.
geposted Fri 10 Oct 14 @ 6:14 am
Mac or Windows?
geposted Sat 11 Oct 14 @ 6:29 am
