I have been using the title plugin for weeks without fail. Now all of a sudden it will not display the cover art with the title only the title will show. I tried to click on the the "show cover"
button in the title config box but then title will not show at all.
geposted Wed 24 Sep 14 @ 3:13 pm
Just tried, and it still shows covers here. Are the covers still visible on the skin when the track is loaded?
geposted Thu 25 Sep 14 @ 7:27 am
Yes they show on the skin but not when the title comes up on the video.
geposted Thu 25 Sep 14 @ 10:20 am
Now playing without the projector it displays fine could it be the resolution being different on the second screen
geposted Thu 25 Sep 14 @ 10:30 am
Did you use videoForceFullScreen? It should probably be set to 0 for covers to work correctly.
geposted Fri 26 Sep 14 @ 8:44 am
got it fixed apparently has to do with screen resolution thanks
geposted Sat 27 Sep 14 @ 2:31 am
