Forum: VirtualDJ Skins
Topic: How do I code tooltips?
Can someone confirm whether you can only assign tooltips to button elements... I'm trying to create tooltips for other elements such as sliders, visuals, waveforms etc and can't figure it out :-(
The other elements are returning info about the state of the element (eg song pos, gain level, VU etc) but I would like to add a line of explanation/use for element aswell.
geposted Sat 27 Sep 14 @ 7:29 am
Almost everything may have a tooltip.
<slider action="" tooltip="Your Text"></slider>
OR
<slider action="">
<tooltip>Your Text</tooltip>
</slider>
Sometime it will show "You Text" as well as a value (i.e. volume sliders or EQ).
In my skin I often want to NOT show any tooltip :
<visual tooltip=""></visual>
<visual>
<tooltip></tooltip>
</visual>
If a type of syntax does not work, just try the other notation, but IMO they are stricktly equal.
Also, you should learn from other skins, I unzip almost all of them and read carefully what I may need in mine.
A waveform isn't supposed to have a tooltip, didn't try yet, but you may perform a trick. Just put a fully transparent visual in front of it that have a tooltip, with the same dimensions as the waveform window. i.e.
<rhythmzone>
<size witdth="1000" height="100"/>
</rhythmzone>
<visual clickthrough="true" tooltip="The best waveform in the world">
<size width="1000" height="100"/>
</visual>
Awesome advice, thanks Fruit! :D
I did try
<slider action="">
</slider>
but didn't work... I'll try again ;-)
Can you paste here a sample of real code ? So we may help you more...
Tooltips on sliders should work... Did you try to add it in the header instead ? i.e. <slider tooltip="Text"></slider>
Here's a real example from my skin :
<panel class="knob">
<panel><visual/></panel><visual/>
<slider action="eq_high" dblclick="eq_high 50%" rightclick="eq_high 0% ? eq_high 50% : eq_high 0%" tooltip="EQ HIGH"/>
<slider action="eq_high" dblclick="eq_high 50%" rightclick="eq_high 0% ? eq_high 50% : eq_high 0%" tooltip="EQ HIGH" frommiddle="true"/>
<textzone><text format="HIGH"/></textzone>
<button action="eq_kill_high" class="mixer_audio_eq_kill" visibility="var '@$v8bf_eq_kill' 1"/>
</panel>
My problem is this... I have created an invisible vertical slider for gain adjustment and placed it over my channel VU meters. this way you can adjust the gain by clicking or dragging when over the VU graphic. This works really well, but the tooltip is never visible. The tooltip which always appears is the one for the VU ('get_level' %'etc).
I have now realised that the VU is snatching focus back when it redraws the level graphic and is suppressing the slider tooltip. I have verified this by moving the invisible slider and the tool tip works when it is not over the VU bit - it works as expected. So....
I need to suppress the VU VDJ generated tooltip and force it to show my slider tooltip instead.
OR
Somehow add my gain feature info to the VDJ VU tooltip.. hmmm :-/
EDIT: I will try your visual clickthrough trick!! ;-)
No joy, the VU stops the clickthrough trick.
My code.. (graphically placed over VU meters of the same dimensions)
<group name="invisible_gain">
<slider action="gain" direction="up" orientation="vertical" rightclick="volume 0% while_pressed" tooltip="Set gain by click or drag">
<pos x="+0" y="+0"/>
<size width="30" height="230"/>
<off x="2100" y="1880"/>
<on x="2100" y="1880"/>
<!-- <tooltip>Click or drag to set GAIN</tooltip> -->
<fader>
<size width="30" height="1"/>
<pos x="2100" y="0"/>
</fader>
</slider>
<!-- <visual clickthrough="true" tooltip="Click or drag to set gain">
</visual> -->
</group>
Why have you commented out the code?
<!-- Anything inside this is ignored -->
I dont want it to execute! The tooltip code is active in the top slider line..
I have tried all variations by un/commenting each in turn
You haven't closed off that line / I'm not sure if that's important.
Its closed off further down, after the nested fader
And, when you hover it with the mouse, does it it give you at least the actual gain value ? And also, does this slider actually work ?
Make sure that your <slider> is after the VU in the XML document.
If that doesn't work let me know and I'll test some more.
Fruit: Once I disable the tooltips for the VU I get the gain value returned in a tooltip. The slider works correctly in all other respects.
Dan: <slider> is immediately after the VU code. All works perfectly if I position it elsewhere, it just doesn't like being on top of the VU. I have also disabled all tooltips for the VU using tooltip="", which does as it should, but the added tooltip text for slider is still absent. Stumped!
UPDATE: I tried my code on my PC in the club and it worked as it should.... :D I will need to retry on my home pc and see if it was just a syntax error somewhere?? To get it working I just added tooltip="" to the VU elements then the gain level showed, including my added text.
Thanks for all the help! :-)
When vu tooltip is disabled, and you try to add a customized tooltip in gain slider, you just keep seeing the gain value ?
all is ok now :D code used is below.
<slider action="gain" direction="up" orientation="vertical" rightclick="volume 0% while_pressed" tooltip="GAIN click or drag to set \n Right click to temporarily MUTE">
<fader>
</fader>
</slider>
</group>
Why this wasn't working before I don't know... I will investigate at home tomorrow and report back.
But yes, mutliple tooltips over the same area would show only one at once, so you have to make a choice and disable the others.
