Forum: VirtualDJ Skins
Topic: Skin bug
I don't know if this is more appropriate in technical, bug, or this board but here will do,
When I put a even slightly complicated script on to a faders action inside a skin, graphically the fader misbehaves. and it will no longer accept keyboarded scripts.
The script, (fader works normally when 'deck 1 effect_active 'volume' == 0, but breaks when it ==1)
deck 1 effect_active 'volume' ? crossfader & param_smaller 2% ? crossfader_disable 1 & deck 1 effect_slider 'volume' 1 100% & deck 2 effect_slider 'volume' 1 0% : param_bigger 98% ? crossfader_disable 1 & deck 1 effect_slider 'volume' 1 0% & deck 2 effect_slider 'volume' 1 100% : crossfader_disable 0 & deck 1 effect_slider 'volume' 1 100% & deck 2 effect_slider 'volume' 1 100% : crossfader
geposted Sat 27 Sep 14 @ 1:26 pm
