Topic: Numark NS7 II
Jason KPRO InfinityMember since 2007
Ran VDJ8 all day at home without problems. Head out to my show and it just kept freezing every few songs with the ns7 ii hooked up. Finally went back to VDJ 7 and everything worked great the rest of the night.
geposted Sat 27 Sep 14 @ 5:05 pm
Any chance you had the Wifi enabled ?
Same USB cables, same computer ?
geposted Sat 27 Sep 14 @ 6:18 pm
Sure did, and always do. Wifi allows freestyler (dmx software) control via a tablet. Has there been issues with VDJ8 and wifi/ns7ii?
Same laptop I've been running for awhile. Specs are:
sandybridge quadcore i7
nvidia something (laptops not here right now) integrated
8 gigs ddr3
widows 7 64
Typically I can run VDJ7 (plugins: slideshow,scrolling text, clipbank, sbdj freestyler, and milkdrop) , Freestyler w/wifi tablet, and visikord software for kinect. While running second monitor. Computer stays around 5-25% and ram is 1.6 to 2.8 gigs used.
Thought automix was giving me issues, so I restarted and didn't use it. Still crashed after about 10-20 mins.
geposted Sat 27 Sep 14 @ 6:54 pm
I used it when it first came out and it worked fine. I needed the plugin for freestyler, and I was having issues with cached tracks. Wonder whats causing the issue right now.
geposted Sun 28 Sep 14 @ 8:03 pm
What's going on here? Is this a known bug that has to do with wifi?
geposted Tue 30 Sep 14 @ 1:37 am
