Topic: sidelist to automix move
Several times I've set up an automix list (for wedding day music) in the sidelist by mistake, it would be great if you could drag and drop from sidelist to automix and vice versa.
geposted Sun 28 Sep 14 @ 3:47 pm
And you can :)
Use CTRL+A to select all files in the sidelist, then drag them on to the automix list icon at the bottom, drop and they will now be added to your automix list.
geposted Mon 29 Sep 14 @ 1:22 am
the following action mapped to a custom button or a keyboard shortcut could be useful to you too.
switch_sidelist_playlist
geposted Mon 29 Sep 14 @ 1:37 am
