Topic: Master Gain issue
Everytime I load a song to a deck on 4 player skin the gain never stays at 12aclock. Everytime I load a song the gains change to every song. How do you set it so the gain stays in one place
geposted Mon 29 Sep 14 @ 9:19 pm
If you don't want to let VDJ manage your Gains go to settings - options and set autoGain to NO
geposted Tue 30 Sep 14 @ 2:32 am
Actually the BEST practice is to set Auto-Gain to "Auto" and enable the "GainSliderIncludesAutoGain" option.
This way when a track loads the initial "gain" will be always correct, and always at 12 o clock :)
geposted Tue 30 Sep 14 @ 2:37 am
True, but AFAIK that is just an optical thing, isn't it?
geposted Tue 30 Sep 14 @ 2:39 am
No, as you combine the best of both worlds. You have autogain active so that it balances your tracks, and you always know that 12 o clock is the place where you need to move your knob in order to catch the gain and adjust it manually if you want. ;)
geposted Tue 30 Sep 14 @ 8:05 am
