I'dont know how to make our own mapping.
geposted Tue 29 Mar 16 @ 9:32 am
Virtualdj8 Supports
geposted Tue 28 Jun 16 @ 9:18 am
I need help to connect my mixer to virtual dj behringer cmd studio 2a
geposted Tue 06 Sep 16 @ 12:44 pm
Which part of the manual are you struggling with
http://www.virtualdj.com/manuals/hardware/behringer/cmdstudio2a.html
https://media.music-group.com/media/PLM/data/docs/P0AVW/CMD%20STUDIO%202A_QSG_WW.pdf
geposted Tue 06 Sep 16 @ 2:07 pm
Some units require drivers, i believe the Studio 2a is one.
Drivers : https://www.music-group.com/Categories/Behringer/Computer-Audio/DJ-Controllers/CMD-STUDIO-2A/p/P0AVW/downloads
VirtualDJ Guide : http://www.virtualdj.com/manuals/hardware/behringer/cmdstudio2a.html
If still not working, try a different USB cable and/or a different USB port
geposted Wed 07 Sep 16 @ 7:39 am
how to mapping cmd 2a in virtual 8
geposted Fri 17 Feb 17 @ 10:05 am
Please read the previous messages.
geposted Sat 18 Feb 17 @ 9:23 am
How can i get a free license to operate my cmd 2a behringer controller using a virtual dj8. Tnx
geposted Fri 17 Mar 17 @ 3:02 pm
You can't get a free license. You need to buy one.
.......or you could pay for a Pro subscription. $19 for a month's use, then if you don't like it, you can cancel.
geposted Fri 17 Mar 17 @ 5:57 pm
good day! how can i get the key code of cmd studio 2a controller, coz my demo has been expired. thanks
geposted Tue 25 Jul 17 @ 1:37 pm
Click the buy link above and purchase it like the rest of us ;-)
geposted Tue 25 Jul 17 @ 2:51 pm
Cmd studio 2a mapping
geposted Mon 31 Jul 17 @ 8:23 pm
Yes. What about it?
geposted Mon 31 Jul 17 @ 8:25 pm
The controller doesn't have a mix preview option in headphones (it only has a volume knob for headphones with no mix knob). What command would map the MODE + headphones knob to control the headphones mix?
Also, separately, how can I assign MODE + pitch knob (1 and 2) to the gain on the two tracks? (The controller doesn't have gain knobs either).
Finally, is it possible to assign keyboard buttons to the master volume (bump it up or down incrementally) - controller doesn't have a master volume either.
geposted Fri 15 Sep 17 @ 5:42 pm
Assign the HEADPHONES_VOL as..
shift ? headphone_mix : headphone_volume
Keep in mind that after using the shift or the non-shift action, the other one's value may not match with the knob's position. In this case - due to the soft-takeover - the knob will start applying to the value of the action, once their values match.
For the PITCH
var 'pitchmode' 1 ? shift ? param_smaller 0 ? loop_move -1 : loop_move +1 : loop_double : var 'pitchmode' 2 ? shift ? effect slider 2 : effect_slider 1 : shift ? gain : pitch
With this action, Gain will work when MODE +PITCH is moved, but needs both ASSIGN button modes to be off.
For keyboard keys to control Master Volume..
A toggle button from 0% to 100% and back
master_volume 100% ? master_volume 0% : master_volume 100%
2 buttons to increase/decrease
master_volume -5%
master_volume +5%
or if you want to increase/decrease while help down ...
master_volume -5% & repeat 500ms 500ms & master_volume -2%
master_volume +5% repeat 500ms 500ms & master_volume +2%
1st time parameter defines the time to repeat increase/decrease action. 2nd parameter wait until the repeats start (a delay)
For the PITCH
master_volume -5%
master_volume +5%
geposted Fri 15 Sep 17 @ 10:20 pm
Wow djdad, thank you for this!
For the PITCH
master_volume -5%
master_volume +5%
For the PITCH
master_volume -5%
master_volume +5%
geposted Sat 16 Sep 17 @ 5:48 pm
good night virtual users dj ..
I want to ask how to setting cmd studio 2a to virtual dj 8 ,, I need help to the authorities .. !!
thank you
geposted Tue 13 Mar 18 @ 3:29 pm
Hi im using virtualdj 8 with the behringer cmd studio 2a,
i have an idea to have better control over the effects
in pitchmode 2 i would like to select the the effects with the pitch wheel (knob) ;
to turn on a effect i would like to use the mode button ;
than changing the effect slider 1 with the pitch wheel (knob) while pressing pitch bend -
and changing the effect slider 2 with the pitch wheel (knob) while pressing pitch bend +
i tried to map it, but my pitch wheel is not chnaging between effects.
can someone help me?
Thank you djanes and djs
geposted Tue 21 May 19 @ 6:45 pm
ok to activate with mode is kinda stupid because it is required in some others functions....any ideas?
geposted Mon 27 May 19 @ 5:58 pm
Get yourself a better controller :-)
geposted Mon 27 May 19 @ 6:14 pm
