Just wondering how some of you transition song to song smoothly. Do you have a certain technique you use often or just freestyle every time?
geposted Wed 01 Oct 14 @ 7:37 pm
You need to know your music. You can use a formula but, think of it more as an outline than a set in stone rule. Have an ideal and, feel your way around it from there. Mixing is an art form. As with all art, it's a personal expression. So, find your own path. Enjoy the journey of discovering that style.
geposted Wed 01 Oct 14 @ 7:54 pm
GAINS
BEATMATCHING
PHRASE MATCHING
EQs
BEATMATCHING
PHRASE MATCHING
EQs
geposted Thu 02 Oct 14 @ 4:35 pm
lucas569 wrote :
GAINS
BEATMATCHING
PHRASE MATCHING
EQs
BEATMATCHING
PHRASE MATCHING
EQs
+1
Also, do some research about the Camelot Wheel (harmonic mixing), by using this method it makes your mix smoother by mixing songs with the same keys. Here's a good article about harmonic mixing:
http://www.djtechtools.com/2010/03/23/to-key-or-not-to-key/
Also, use Google or Youtube there are tons of tutorials out there :)
geposted Thu 02 Oct 14 @ 5:31 pm
also not every song needs to be mixed, some simply cant. BUT i will admit i do add a 4 to 8 bar loop on some songs to make it more dj/mix friendly.
geposted Fri 03 Oct 14 @ 4:39 pm
