Topic: Pitch Control Issues
Can't figure the setting for the pitch control. Everytime I load a track the pitch control moves all over. I want to set it to 0 and forget it. What's the settings I need to do this
geposted Thu 02 Oct 14 @ 12:47 pm
It's a config option called autobpmmatch which needs to be set to 'off'.
There are many messages here from people who've wondered what the hell is happening.
IMO Atomix ought to make 'off' the default.
geposted Thu 02 Oct 14 @ 1:39 pm
Thank You!!!! I have a job tomorrow, and just really noticed this as I usually bpm match my tracks anyway(+/-2bpm). I was going back to 7 until I found this post. I also agree that this should be off by default!!!
geposted Fri 03 Oct 14 @ 1:22 am
Just trying V8 and 'Yes' I get the same, the pitch changes as you start the next track. The 'autoBPMmatch' is on 'no'
geposted Tue 16 Dec 14 @ 11:19 am
Have you turned on smart play? It's off by default.
geposted Tue 16 Dec 14 @ 12:25 pm
