VDJ7 with my MAC and Denon MC 3000 works fine. Can NOT get VDJ8 to illuminate the Denon MC 3000 buttons. Functions works fine, however, will not illuminate any of the MC 3000 buttons. If I switch back to VDJ7 controller buttons come on. HELP!
geposted Sat 04 Oct 14 @ 5:30 pm
You have to modify the mapper, just check in all keys if you can seen keys with "LED" at the beggining. If yes, you will be able to map them with an action of your choice.
geposted Fri 10 Oct 14 @ 8:34 pm
which build of VirtualDJ 8 are you using ? Has it ever worked with 8 for you ? or is this the first time you tried ?
geposted Fri 10 Oct 14 @ 8:50 pm
That's really odd since every build of VDJ8 worked with my 2000, 3000, 6000, and 6000MK2. (No problems with button illumination or functionality.)
geposted Fri 10 Oct 14 @ 9:27 pm
