var '@$v8bf_skin_tint' 20 ? set '@$v8bf_skin_tint' 21 : var '@$v8bf_skin_tint' 21 ? set '@$v8bf_skin_tint' 22 : set '@$v8bf_skin_tint' 20
Standard schemes are numbered as follow :
0 > native
1 > raw
2 > default
3 > day
4 > plume
5 > lime
6 > strawberry
7 > superman
8 > electro
9 > dark
10 > tangerine
11 > kitty
12 > haze
13 > flower
14 > ocean
You may also choose to display the bright tint workaround by toggling this var :
@$v8bf_tint_bright
1 > on
0 > off
Example :
var '@$v8bf_skin_tint' 20 ? set '@$v8bf_skin_tint' 21 & set '@$v8bf_tint_bright' 1 : var '@$v8bf_skin_tint' 21 ? set '@$v8bf_skin_tint' 22 & set '@$v8bf_tint_bright' 0 : var '@$v8bf_skin_tint' 22 ? set '@$v8bf_skin_tint' 3 : set '@$v8bf_skin_tint' 20
geposted Tue 12 Apr 16 @ 5:04 pm
You are a script genious
geposted Tue 12 Apr 16 @ 5:42 pm
OLOL no :)
Locodog is, I'm kinda crappy at scripting, I just know some basics... but thx anyway :)
geposted Tue 12 Apr 16 @ 5:51 pm
Let me ask if permitted and if it is possible.
Sir Fruit,
Can you please script for the new skin to show a toggle between vu meter and master meter output? Your input would be priceless.
Sir Fruit,
geposted Tue 12 Apr 16 @ 6:42 pm
toggle '@$v8bf_vu_source'
geposted Tue 12 Apr 16 @ 8:29 pm
Since there's no SDK for this skin yet, you're of course free to ask any/everything. I'll answer with great pleasure (if that thing can be done).
geposted Tue 12 Apr 16 @ 8:32 pm
Thank you Fruit, Sir
geposted Tue 12 Apr 16 @ 9:47 pm
Hey Fruit! You made the best skin for VDJ!
I'm trying to customize it further, so i got 2 questions for you:
1. Is there a way to use the space occupied by the jog wheels to show the LOOP buttons (or any other panel)?
2. Is there a way to make the Title Bar smaller / thinner?
Regards!
Regards!
geposted Fri 20 May 16 @ 1:49 pm
1. For now you can only show a video window instead of the jogwheel (in deck menu / wheel / video)
2. No
2. No
geposted Mon 23 May 16 @ 3:00 pm
Thanks for the reply Fruit!
geposted Mon 23 May 16 @ 7:49 pm
Np :)
In addition, for 1. it might evolve a bit so you're able to show more panels in the jogwheel area. But I can't really say which right now.
geposted Tue 24 May 16 @ 7:34 am
That would be really cool. Thanks for taking it into consideration!
geposted Tue 24 May 16 @ 5:04 pm
Can somebody please confirm if this skin works as per below?
Controls - On my laptop
Extra Monitor - Browsing
VGA Out - For the Videos that I play
geposted Fri 27 May 16 @ 6:43 pm
Sure, just select the layout menu (top left corner) / 4 decks w/ext browser.
geposted Sat 28 May 16 @ 10:03 pm
Hey FRUiT,
may I ask for someting to put on the to do list;
is it possible to fill the empty space here with custom buttons that would be global, regardless of the skin view, just like always there?
this is always lots of empty space that I would like to use for my standard buttons, colors, search file/folder etc ... imv humble o ;-)
lot's of luv
ray
lot's of luv
ray
geposted Tue 31 May 16 @ 9:41 pm
Will add this in todo list.
Cheers my dear good friend :)
geposted Thu 02 Jun 16 @ 8:53 am
does the skin play nice nice with the new 8.2 version?
geposted Tue 07 Jun 16 @ 12:27 am
Yes it does (so far). been playing around with it for couple of hours, only thing I've noticed is the waveform is a bit juddery but then it settled back down, but so everything works fine
geposted Tue 07 Jun 16 @ 12:35 am
Works fine for me, but 8.2 is still in early release (public beta).
geposted Tue 07 Jun 16 @ 1:07 am
The row of custom buttons would be a welcome addition. Especially if it was above the browser, kinda like the silversleek skin. Many thanks for my fave skin of all time Fruit :)
geposted Tue 07 Jun 16 @ 10:16 am
