Forum: Addons
Topic: V8 but by FRUiT - Page: 36
Win 10 x64 and everything is ok with 4848 & 4909 v8 x86, as is my x64 build.
You could always try clearing the global variables line in settings.xml as it keeps all the skin specific settings and the fruit skin saves it's user settings there.
<VDJScriptGlobalVariables>
That was it! There was a hell of a lot of stuff stored in that part of my settings.xml but now it's been cleaned, the skin works fine.
So the fact it worked on my 32 bit PC and not my 64 bit was simply down to how much dross there was in that part of the settings file on my 64 bit system.
It's the option for cue position top/bottom that causes the issue, for now don't pick either.
Hello folks ! Just cleaned the variable, and it works again !
Thanks a lot kradcliffe for the tip :) (I think you made many more happy ! )
For me this skin is the best you can find for VDJ because it's aboslutely fully customizable ! (thanks again Fruit by the way !!)
Getting weird things happening with the skin on the latest VDJ Build (4973)
Notably on the left deck (weird red surround), the phrasers, where artwork appears, where the clock & settings menus appear, (grey surround), the volume sliders & gain buttons have a weird gradient now too...
Running OS X 10.11.6. Scared to update to 10.14
Looks to me the skin has reset everything to FLATTEN, Just uncheck them all
I want it to be flattened.
Turns out i had the 'Experimental Skin Engine' feature set to enabled. Disabled it and it fixed all issues.
Hi, since the last update b5046 the "remaining time or total time" in the top right is algined left, so its swapping over the wave.
system mac
I switched back to 5003, everything fine
Can I repair it inthe settings.xml?
Thx omar
I would wait until Atomix fix the issue...
Since they added the browser padding option, many skins have problems with display of text.
If you fix it to work now, then it'll likely be wrong again after a future update.
Thx, Okay, then I'll be patient. (-;
Confirming that I am experiencing the same issue with this skin! Deck two time misaligned! MAC user running macOS Mojave 10.14
I love this skin is the best, but can you please just put it with "NUMBER OF DECKS 2" option?
In the rest I am satisfied.
Thank you
Hello Fruit, how are you!
First, I will congratulate you for excellent work on this skin!
Now, I have a question about custom button color: "custom_button 81624"
I would like to change the color of this button
It's possible to do that?
One more question = In "POI Editor"
How can I add a keyboard shortcut with a macro function in hotcue?
For example: I have added this shortcut to techa number " 1 " from my keyboard:
set_cue 1 & cue_color 1 cyan & cue_name 1 "1 Start" & doubleclick? delete_cue 1
I would like to set a macro function of the POI, but I don't know how to do it!
https://www.virtualdj.com/img/223754/15761/POI%20Editor%20Main.png
Anyone having any issues using FRUiT's skin with the latest version of VDJ 2020? Just wanna be sure I can continue to use this awesome skin before I update!
Why don't you just try it? It's a bit early to be asking if anyone's had issues, considering 2020 is just out.
Try it, see if you find any issues, then report them back here.
There are so many options in the FRUiT skin, even if someone had tried it in the few minutes since 2020 was available, it's unlikely they would have exactly the same skin setup as you, and be using it exactly the same way as you.
Fruit wrote :
Discussion about V8 but by FRUiT
will you be updating this skin now 2020 has been released.
i.e new digital clocks ect and less clutter easier on the eye ect.
as i love this skin.
cheers
He hasn't been on the forum for aaaaaaaagges......
Probably just busy getting on with life.
95%
