Topic: Remaining Timecode-Issues
Support wrote :
Date: Wed 08 Oct 14 @ 11:31 am
Teamer: Support Staff
Message:
Hi,
i'm sorry to hear that.
Maybe it is time to start a new topic about that on Beta Forum side.
As far as we have heard is new TC update on the road.
The sad thing is, we have no idea when this will be released.
Kind regards
VirtualDJ Support Team
ATOMIX PRODUCTIONS
... - hereby done =)
I keep on complaining about skipping music when turning timecode on.
Also I get vast skipping while scratching (every tc-mode).
What else do you guys still experience?
geposted Wed 08 Oct 14 @ 6:20 am
The pitch is off when u try to mix it a song it is very hard to keep it in sync with the other track it go - then + to much so say u are mixing and u are using the pitch slider on the turntables to try to keep sync with the other track move the pitch a little bit to + the pitch slider on the software move to much to + and the same thing with - so it throw u off beat a lot and I try every setting there is for timecode pitch control.for me that the problem I am and having .even if I try to press the sync button still the same thing happens it like the sync button does not even work on timecode vinyl.
geposted Wed 08 Oct 14 @ 6:45 am
As you know, there is already an existing thread running on timecode, so apologies on behalf of the person who advised you to open another but it's really not necessary.
Some updates to the TC engine are definitely in progress though.
geposted Wed 08 Oct 14 @ 8:08 am
