Topic: Beatlock Options
djlk4uPRO InfinityMember since 2008
Is there any way in VJ8 for the beatlock to behave the same as V7?
For example there was only 1 button to click in V7 and all decks were locked, so regardless of which deck your moved, all others corresponded. (Sort of like a Global Master Tempo like Traktor)
Now I have to think about which deck is going to follow the other one, then I have to ensure that the Master is selected (usually its not for the activity I'm thinking about-see below)
I understand that V8 has this feature so that any deck can be selected or deselected to follow the Master Deck but this would be a great feature if only 2 decks were being used.
I use this feature specifically when I have a large BPM difference and I am looping both decks then speeding or slowing decks simultaneously to get to the desired BPM
Any help would be greatly appreciated. Thanks guys...
ps I see a weird slipping of the slave deck after it's been stopped and still in beatlock mode. This did not happen in V7
geposted Thu 09 Oct 14 @ 1:09 am
You could try mapping something like this:
get_deck 4 ? deck 1 beatlock & deck 2 beatlock & deck 3 beatlock & deck 4 beatlock : deck 1 beatlock & deck 2 beatlock
geposted Thu 09 Oct 14 @ 2:39 am
this worked well for me. Thanks so much PachN! Actually I deleted the 'get_deck 4?' and kep the rest and it worked great!
Thanks agin!
geposted Sat 11 Oct 14 @ 8:24 pm
