Forum: VirtualDJ Plugins
Topic: Cut plugin needed. VDJ8
geposted Sat 11 Oct 14 @ 1:10 am
Any word on this?
geposted Sun 09 Nov 14 @ 10:02 am
+1
geposted Sun 09 Nov 14 @ 12:38 pm
TKO-84PRO InfinityMember since 2014
I'm waiting on that one too...
geposted Mon 24 Nov 14 @ 5:14 pm
I'm guessing there is no luck on this one... sucks..
geposted Thu 05 Feb 15 @ 12:27 pm
rename cut.dll to cut1.dll, be warned though it can cause crashes.
geposted Thu 05 Feb 15 @ 6:05 pm
geposted Fri 06 Feb 15 @ 10:59 am
Scott, will this work with the cut for video aswell?? I really miss that plugin.
EDIT
Just saw the second one is for video!!
You sir are wonderful!! Thank you!!
geposted Fri 06 Feb 15 @ 11:28 am
The second link is an audio visual cut - no need for two seperate plugins any more :)
I've given these an adjustable wet/dry too - and that applies to the video cut too.
geposted Fri 06 Feb 15 @ 11:29 am
Sic!! 😜
geposted Fri 06 Feb 15 @ 12:26 pm
Scott, great as always
But I have 1 request, can you please switch the knobs around?? Make the first one the cut and the second one the wet/dry.
For midi controllers I use my DJM T1 and a DDJ SP1, for both of these when I have them set to multiple effects I have to hold down the shift button to control the cut. It just doesn't flow or feel right when I use the plugin the way it is now.
Can you please switch the knobs around??
geposted Fri 06 Feb 15 @ 11:05 pm
@SBDJ
thanks much appreciated
geposted Sat 07 Feb 15 @ 6:47 am
Can you not just swap the mapping around, so knob 1 moves slider 2 and knob 2 moves slider 1?
geposted Sun 08 Feb 15 @ 12:36 pm
I suppose, what's the script??
geposted Sun 08 Feb 15 @ 12:57 pm
