Hello,
I have a midi button mapped to work like this: deck 1 effect_active while_pressed "Beat Gird"
and if I change the effect inside the skin (Example: distortion)
It will enable the distortion effect instead of Beat Grid. It's completely ignoring the part of the script where I chose my effect to play on that midi map.
BTW I'm using the Mac version.
geposted Sat 11 Oct 14 @ 1:22 am
why are you put "Beat Gird" in your script, you don't need
geposted Sat 11 Oct 14 @ 1:59 am
Maybe a silly question.....but... you have "gird" instead of "grid"
geposted Sat 11 Oct 14 @ 2:13 am
test
deck 1 effect_active 1 "beat grid" while_pressed
geposted Sat 11 Oct 14 @ 2:22 am
HAHAHAH! solved!
geposted Sat 11 Oct 14 @ 2:23 am
ROFL!
Just goes to show though, that's there's no check happening anywhere.
Ideally there would be a message along the lines of "Effect Beat Gird not found", so at least you'd have some clue as to why it wasn't working.
geposted Sat 11 Oct 14 @ 4:57 am
I suggested, like spell check, stuff not understood should get underlined, on short stuff it's easy to spot a mistake, but with long scripts it's a nightmare if you miss a space or use a ; instead of a :
+1 it
http://www.virtualdj.com/forums/193961/Wishes_and_new_features/Mapping_wish%28es%29.html
+1 it
geposted Sat 11 Oct 14 @ 5:22 am
Yes, there's a basic check for filter strings (when making a filter folder), but it needs to be in place elsewhere too.
The more complex VDJ gets (custom buttons, action POIs...) the more need there is for this process to be made easier for the end user.
geposted Sat 11 Oct 14 @ 5:30 am
.. and the more it checks for errors etc, the heavier it will become ?????? Just a though ;)
geposted Sat 11 Oct 14 @ 4:40 pm
I like people sharing thoughts, so thanks djdad but.....
Why does it have to be heavier? (How often do you write scripts/edit POI etc in a performance setting?) it could faux perform the script and underline where it stops/fails.
Option-ize it (button in the mapping section, check script) and then it is only used when there's a problem.
"Let the machine do the technical stuff" isn't that an Atomix mission statement?
If making it heavier was such a concern why can't my Craptop display 4 deck HD waves? (sarcasm)
geposted Sat 11 Oct 14 @ 5:16 pm
