Topic: Crash immediatly when loading any track
Hi, my system runs Virtual DJ 7 perfectly,
So, i just installed VD8, and loading a track locks up the software totally - the song can play, but nothing works and track info never shows up. This happens every time i start up VD8! Any idea on what to do??
geposted Tue 14 Oct 14 @ 3:52 pm
you guys aren't gonna make me go buy traktor are ya ;) I need 4 decks!!
Okay so, I'm using Windows 7, ordinary setup, standard audio drivers, and Virtual Dj 7 works perfectly on this system,
but when I load VDJ 8 and try to load a track, it just crashes the entire software, no knobs can move at all, no sliders,
no waveforms show up - but if I hit play, the song plays, but nothing else functions...
Is this abnormal, any clues to the cause??
geposted Wed 15 Oct 14 @ 7:29 pm
It happens when you load a track.....
Load a track from where? Internal drive, external drive, Grooveshark/Content Unlimited?
Are you loading it from within VDJ (it's been added to the library) or are you dragging & dropping from somewhere?
What type of track is it? What format? Video? Audio? Is it a single track or a long mix?
What skin are you using? Your comment about knobs and sliders not moving makes me wonder if perhaps you're trying to use an old skin.
geposted Thu 16 Oct 14 @ 5:39 am
