Hello and sorry for my English ;)
Material used:
- Native Instrument Traktor A6
- Hercules RMX
- PC ASUS i7 / 8GB / Windows 8.1 64x
- VirtualDJ 8 (2003)
- The drivers and computers are up to date
When I want to configure and map VDJ8 A6 ASIO mode for use timecode, audio does not work.
Calibration is done in "IN" but nothing in "OUT".
If I use the A6 only for External Deck 1 and Deck 2, the sound card is working properly in ASIO mode.
I did the same configuration with a Hercules RMX and timecode running smoothly.
With OSX, both works fine but there is a sizzling sound in a small scratch. But I think if the problem is known.
I have not posted in the "TOPIC: TIMECODE (OFFICIAL THREAD)" because I do not think it's a problem with the settings VDJ8 but for the sake of recognition A6 card in ASIO mode.
Material used:
- Hercules RMX
geposted Thu 16 Oct 14 @ 2:12 am
I use the A6 card with VDJ8 and time codes in ASIO mode. It works perfectly. I suggest you do a factory reset and try calibrating again. My Traktor A6 gives perfect signal with both VDJ and Serato timecodes
geposted Thu 16 Oct 14 @ 3:15 am
Thank you for your answer .
If it works for you, there is no reason I can not do it :)
I'll get .
thank you
I'll get .
thank you
geposted Thu 16 Oct 14 @ 3:55 am
It's okay, I understand too why but when I selected the vinyl (Serato V2) and then I calibrais, nothing happened.
I restored the default setting and I just switched a calibration and it's good;)
Thank
Thank
geposted Sat 18 Oct 14 @ 2:55 pm
