I do not have enough "options" for automix
Automix setting should be separate from mix and not affect the other
- length of curve mix varies from one song to another why? Has to be fixed.
- in and out options, like cue options only for automix
- indicator on wave should be selectable to be able to vary end point before song ends ( too small right now, too easy to make a mistake) ( a big triangle sideways that changes color when selected that will also not skip song when touches the point of play by mistake)
geposted Thu 16 Oct 14 @ 7:26 pm
Sorry I forgot last point:
- add and option for max length of time for song.
And from what I read, fix the POI bunching problem
geposted Thu 16 Oct 14 @ 7:31 pm
