Forum: VirtualDJ Skins
Topic: Sample Bank
Does anyone know if there is a skin with MORE than just a bank
of 12 samples. 16 would be idea but if there was one with more,
even better.
Any ideas?
geposted Fri 17 Oct 14 @ 11:42 am
If you mean for vdj8 the more samples u add to a bank the more it should expand think they go up to 64?
geposted Fri 17 Oct 14 @ 11:45 am
I'm using VDJ7 at the moment but if need be I would just upgrade to VDJ8
geposted Fri 17 Oct 14 @ 12:23 pm
geposted Fri 17 Oct 14 @ 2:29 pm
I have sample manager but I need to assign buttons on my mixer to samples and they need to be already in the sample bank.
I just wondered if there was a skin that allowed more than 12 samples at a time. I currently use V-Mix 5.4
geposted Fri 17 Oct 14 @ 7:09 pm
on vdj7, you can't show more 12 samples, you need to create banks
geposted Fri 17 Oct 14 @ 11:30 pm
Be aware if you do move to VDJ 8 then that skin will need the XML code updating in order to work fully.
This version updated for VDJ 7 should work OK in 8 though.
geposted Wed 22 Oct 14 @ 7:49 am
