Topic: Database Connection
FLeX69PRO InfinityMember since 2006
Hello VDJ team,
Last night I had an 8 hour set and intermittently I could not see/search the songs in all folders after the first 2 hours of my set. I figured out I had to reestablish connection to the internal hard drive when it occurred. This is the first time this ever happened. I'm not sure if this is tied to the last update and I appreciate your advice. Thanks Flex
geposted Sat 18 Oct 14 @ 1:15 am
"Internet Hard Drive" ? What exactly do you mean by that ?
geposted Sun 19 Oct 14 @ 12:51 am
Hello djdad,
I stated internal hard drive. I appreciate your assistance.
geposted Sun 19 Oct 14 @ 7:25 am
Still dont get it.. sorry ....
"I figured out I had to reestablish connection to the internal hard drive when it occurred."
How exactly do you reestablish connection with the Internal Hard Drive ??? It is not something that you can unplug and re-plug, right ? Is that the C Drive ? Please provide more info.
geposted Sun 19 Oct 14 @ 7:50 am
I had to right-click on the drive and add to search database.
geposted Sun 19 Oct 14 @ 7:58 am
