Topic: set up and NDX900 mapper issues
turtellPRO InfinityMember since 2011
I am running vdj8 with vms4 and 2 ndx 900's. In vdj7 I used to be able to set the ndx's to decks 1&2 and the vms4 to decks 3 and 4 and can't figure it out for vdj8. Any assistance is appreciated. Also having trouble with the ndx900 mapper not always working with all the functions.frustrated.
geposted Sun 19 Oct 14 @ 4:53 pm
VMS4 is a 4 deck controller, so you cant really assign it only to 2 decks. You could of course use the SHIFT+PAUSE buttons to swap the left and right decks of the VMS4 so that you can work with decks 3 and 4 with the unit.
For the NDX900, you will have to be a bit more specific of what is not working.
geposted Mon 20 Oct 14 @ 8:10 am
