Forum: Old versions
Topic: Virtual 7 problems with Mac
Hi guys & girls, i've just gone from PC to Mac and i'm having some problems with the video effects and sound...
I'm using a 27" iMac with a Denon MC6000 mk2 and running Virtual DJ Pro 7 (as 8 doesn't have clipbank yet)
Video Problems: When i load or play an MP3 audio file (PC) clipbank allows my visual loop to play on the preview video and the live monitor however on the Mac the visual doesn't play on the preview window just the main output window - So basically i have a black screen, is this whats suppose to happen as i'm using a Mac and not a PC?
Sound Problems: Every time a track loads whether its on auto mix or just normal play mode the sound is very loud and the levels on the denon controller are in the red, i've found the ply way to avoid this is when the track loads in, turn the gain right round then back down - This seems to fix it..... My only concern is this doesn't seem normal to me....
I would apprecaite any help or advice.
Damian :-)
geposted Thu 23 Oct 14 @ 11:22 am
