Forum: Old versions
Topic: Numark Mixtrack Quad with Virtual DJ 7 Pro
So I recently bought the Numark Mixtrack Quad. It is an amazing controller but there is something wrong with Virtual DJ 7.
I got LE with it but the Pro one that I already had, did not work. So I installed LE. The LE ran the controller fine but it did not have the same stuff the Pro version had. I tried changing the options for audio and everything in 7. Nothing says that the controller is visible. (The audio still comes out the controller though)
I have Virtual DJ 8 lite which does direct the controller but the audio on 8 is weird. It makes a static sound. I think its my sound card or sound driver. It also glitches the controller. It lights up everything and the nobs are all messed up.
Is there any way to get this working on 7 and not LE or 8?
Operating system is Windows XP Service Pack 3. (Previously installed: Windows Vista)
geposted Fri 24 Oct 14 @ 8:24 pm
so do u have a licence number can lend me for the numark mixtrack quad
geposted Thu 09 Mar 17 @ 7:49 pm
