During my work on updating an old skin for a Pro forum member, I have noticed some odd behaviour with some visual code in VDJ 8.
The code displays a visual with volume as the source, but the visual is not responding as expected.
The visual correctly responds to volume when its direction is 'right' (volume up = visual shows) but is reversed when the direction is 'left' (volume up= no visual). The visual shows when the volume is down, which is wrong. Regardless of the direction assigned, the visual should show when volume is up.
Also the visual does not respond to crossfader position. It only seems to work with channel levels.
In VDJ 7 and earlier, it responds to any change in volume, including the crossfader.
geposted Sun 26 Oct 14 @ 7:38 pm
