I was using the platter as a jog search in the second deck then the program had a crash.
Build 2003. Windows 8.1 Pro
You say that V8 is now fully stable and its crashes a lot, second time in this week.
Do I have to downgrade to V7 to use it with no fear?
geposted Mon 27 Oct 14 @ 4:39 pm
The last crash we had from you was with build 1923, which means that either you were not online (connected to Internet) when the crash occurred, or you got a Windows crash/freeze and not a software one.
Are you able to reproduce it and provide the steps to the Dev Team ?
geposted Mon 27 Oct 14 @ 4:47 pm
I am unable to reproduce, because it happens randomly.
The program closes, then a message of Windows appears. I Just have the option to close the message. I have internet connection.
When I restart the program, it behaves like I didn't used it when it had a crash, unlikely with the others versions, that the program restarts playing the same music when it crashes.
I think that the problem consists in the USB HID Library, some kind of synchronism in the USB pool interval, I remember that I saw in a ChangeLog that the dev team moved some config in the LED interval. After that, I am experiencing crashes.
My controller is a custom controller that I've made based in the HID. I can send the device.xml if you want.
At the moment, I have a impasse in what version to use, the V8 offers better sound quality, POIs, and sampler pads, but unfortunately crashes and can not record samples without manually adding then to a slot, thus the V7 have better controller integration, but worst sound quality, horrible filters and effects integration and poor search resources. All of the undesired V7 characteristics is compensated by the stability.
geposted Tue 28 Oct 14 @ 4:40 am
So, this happens only if this HID controller is connected ? which device is that ? Yes, please send the mapping & definition files to check (use babis@virtualdj.com )
What you experience is a Windows crash, not a software one, so we dont get that crash in our servers. If you think that the new increased LED refreshing rate is what causes the crashes, then you can decrease that from the Options (search for ControllerRefreshrate setting and set it to a lower value, e.g 0.5, 0.2 or even 0.1). If that is the cause of the Windows crash, then most likely it has to do with the poor performance of your computer, OS or USB port internal driver. What is your Operating system ?
geposted Tue 28 Oct 14 @ 5:48 am
Email sent, please verify.
I am using Windows 8.1 Pro x64, all drivers are updated.
I will make a dual boot with Windows 7 to have tests, so we can discard windows crashes.
To remember, it's a customized controller, you can visit my blog to see it more in details: http://gmazoni.wordpress.com/2013/11/21/controladora-hid-usb-para-dj-compativel-com-virtual-dj-em-breve/
At the moment, I uninstalled the VDJ8 and I'm using the VDJ 7.41 for stability with no problems.
geposted Wed 29 Oct 14 @ 12:36 am
