Topic: Cannot save VST settings
GGCOMPRO InfinityMember since 2008
Hi:)
I cannot save/load presets in certain vsts..
( using vst2.4 for vdj)
Would like to use my existing vst3s though.. Are they supported?
- suggestion- define location of your vst folder. // also, is it possible to make shortcuts to your vsts in the vdj plugs folder
OT- Is vdj 64bit?
Sorry for being so lazy right now, kinda need some chilltime:p
geposted Mon 27 Oct 14 @ 7:41 pm
i have recently encountered the same issue with izotope ozone 5 vst
no trouble loading presets but cant save new ones. saving presets works fine outside vdj 8.
geposted Mon 27 Oct 14 @ 8:40 pm
geposted Tue 28 Oct 14 @ 8:16 am
