Just spotted this. Not a bug in VDJ but still something that's not behaving as it should.
In the default 6 deck skin, there are 6 mini decks below the 2 main ones. On the top right of each mini deck is a button marked M.
Presumably this is supposed to select each mini deck as the master, and have a tooltip that explains.
Instead, the tooltip reads the same as the tooltip for the deck number buttons ("set this deck as left deck" etc) and clicking the M doesn't make the deck master.
geposted Wed 29 Oct 14 @ 11:36 am
The M buttons work...they set each one of the decks as Master. Its just the Tooltip that doesnt appear correctly.
geposted Wed 29 Oct 14 @ 12:35 pm
Ah yes, I can see now (by assigning masterdeck to custom buttons on each main deck, the buttons change colour).
I thought that the large A and B squares were supposed to show which deck was master.
Tooltip still needs fixing though. :-)
geposted Wed 29 Oct 14 @ 12:48 pm
Will be fixed in next build (installer to be more accurate)
geposted Wed 29 Oct 14 @ 12:59 pm
