I have been using my DJ IO soundcard with Virtual DJ for years.
Settings in Virtual DJ 7.0.5
No inputs.
External Mixer. Deck 1: Ch 1/2 Deck 2: Ch 3/4
Asio Driver. Asio Config to 1024.
Now this has worked fine as I then run two outputs to mixer and am able to use the mixer in the traditional fashion.
However, when I try to use the sound card with Virtual Pro 8, the channels are NOT being split between the two outputs...even though the settings say it is.
Any suggestions to resolve? Thanks
Editted: words
No inputs.
Editted: words
geposted Wed 29 Oct 14 @ 11:06 pm
Hi Dave,
I'm not in front of my laptop, but if I remember right, try these settings.
Output: Speakers
Card: ASIO (The DJ I/O)
Then under source, change the first option to Deck 1, soundcard to the I/O and the Channel to Chan 1&2. Then on the next line add Deck 2, soundcard to the I/O and the Channel to Chan 3&4.
I'll double check my settings later, but I'm pretty sure this is how I was able to get it to work.
Output: Speakers
geposted Fri 31 Oct 14 @ 10:39 am
@DaveDaverson.
The option to use a sound card as separate deck outputs (External mixer /deck 1, deck 2) requires an analogue mixer License , which you will need purchase from the PLUS controller section http://www.virtualdj.com/buy/index.html (the first one from the list)
VirtualDJ 8 (Home Free- No License) will allow you to use your external USB sound card (with ASIO or not), only as Master & Headphones
geposted Fri 31 Oct 14 @ 3:23 pm
Ok, so I just bought the subscription for VDJ Pro, and I am trying to hook up my laptop to the DJIO2, the DJIO2 to my mixer, and run the headphones out of the djio2. What is the recommended settings within the config section? Thanks for any advice!
geposted Tue 18 Aug 15 @ 8:37 pm
Output 1&2 - Master
Output 3&4 - Headphones
geposted Wed 19 Aug 15 @ 4:50 am
i use dj i/o with virtual dj 8 & i only got one channel alone playing & not both side :(
geposted Sat 21 Jan 17 @ 10:59 pm
Please read this whole thread, thank you.
geposted Sun 22 Jan 17 @ 8:24 pm
How to connect Numark io to cdj and virtual?
geposted Mon 17 Dec 18 @ 2:09 am
How to connect Numark interface to cdj?
geposted Mon 17 Dec 18 @ 2:12 am
