Forum: Old versions
Topic: WEGO and headphones
Hi, just bought the original WEGO to mess about with at home
Can someone please tell me can I use my PC speakers for audio and cue using the headphones at the same time?
geposted Fri 31 Oct 14 @ 5:15 pm
you could but you will need to plug the speakers into the wego main output if u want to utilize its audio.
if not to use the headphone with your on board speakers you will need a second output on the pc to plug the headphones into.
i don't think u can mix the wego ASIO with on board waspi to use them both together.
pretty sure as soon as u turn on ASIO all other stuff can't be selected.
thanks, will just use my amp and main speakers then.
