Forum: Old versions
Topic: How to change the folder location :\VirtualDJ\database
geposted Tue 04 Nov 14 @ 3:27 am
You can't change the location of the database only.
You need to change the entire location of VirtualDj home folder.
And it must NOT be on an external (removable) drive.
geposted Tue 04 Nov 14 @ 3:36 am
But VirtualDj home folder and the database-folder two separate folders. If you delete databaseFolder - it appears. Why not do that all in one folder stores
geposted Tue 04 Nov 14 @ 3:53 am
Are you doing this on an external drive ?
geposted Tue 04 Nov 14 @ 10:18 am
it is self-created on the second local disk
geposted Tue 04 Nov 14 @ 7:55 pm
That's the normal expected behavior and it CANNOT change.
It cannot change because it holds all the info for the files on that particular drive (local database)
geposted Tue 04 Nov 14 @ 8:22 pm
PhantomDeejay How do I make it appear in a different location? or in the same folder where you installed the program
geposted Thu 13 Nov 14 @ 5:14 am
You cannot change the location of the database files.
geposted Thu 13 Nov 14 @ 8:38 am
Why create two folders virtual dj8 with database..it s stupid
1. C:\Users\Name\Documents\VirtualDJ\database
2. D:\VirtualDJ\database
geposted Fri 19 May 17 @ 1:50 pm
On the contrary, it is very smart and convenient to have the database stored to the Hard Drive the tracks are saved.
The database created in the C Drive holds information for the tracks stored in the C Drive
The database created in each External Hard Drive holds information for the tracks stored in that Drive.
The most common case is to have your tracks on an external Hard Drive, and then plug it to any computer (even your friend's), run VirtualDJ on that computer and have the database with all the track's info (BPM, Cues etc) available. You may imagine what would happen in this case, if the database for the tracks stored in an ext Drive was in your main computer, right ?
geposted Fri 19 May 17 @ 4:16 pm
Vic666PRO InfinityMember since 2014
I hv a Mac + PC
Now on my Pc the database is in C drive
I like to hv all my audio music / videos however as a backup in D drive as tiz laptop is for other use as well.
I want all my hotcues and relevant bpm/lengths/tags to be intact.
Running on Windows 7 : vdj 8.2 public build 3994
How do I go about doing it. Currently, no issues on Mac as itz use solely with Controllers.
For the PC is basically juz to backup but need all the database to be available.
Any pointers / suggestions is highly appreciated.
TIA.
geposted Fri 23 Mar 18 @ 7:27 pm
Vic666 wrote :
I hv a Mac + PC
TIA.
read https://www.virtualdj.com/wiki/VirtualDJ8_Backup%20Database_.html
geposted Fri 23 Mar 18 @ 9:08 pm
ScooxHome userMember since 2018
Just noticed the pesky VirtualDJ folder on my D: drive and it was bothering me, I mean, how dare VirtualDJ create this ugly folder on the root of my pristine data partition? But after reading djdad's explanation it makes perfect sense. The folder doesn't look pretty but I've set it to 'hidden' and it's all good now—out of sight, out of mind.
geposted Tue 27 Nov 18 @ 3:08 pm
