Latest versions of virtualdj 8 have a problem and the name of the songs, etc, the browsing of the files overall, don't show correct on the screen. If you "squish" the columns, the titles re-appear and if you change the BPM place (you move the BPM column first) it also re-appears. But this is not fuctional, neither normal or fuctional. Also, only a part of the screen works when you "squish" the lines. The same problem occurs on the browsing choices on the left.
Because my english are not good enough, here is a video that shows the problem in detail: https://www.sendspace.com/file/j7vrvn
On this video, I show you the previous version of virtualdj 8 (the browsing is OK), then I upgrade to the latest version and the problem appears. Then, I try to repair the file by re-installing it, but the problem remains. Then, finally, I revert to the old version of virtualdj and all is again ok!
I'm with windows XP SP3, on an acer 6292 laptop (it has intel X3100 graphic card).
When I reinstall previews versions of virtualdj 8, everything is OK.
geposted Tue 04 Nov 14 @ 6:39 pm
Labrokratis wrote :
previews versions
Previous versions (earlier versions). :-)
geposted Wed 05 Nov 14 @ 5:00 am
Yes this, earlier versions! Thanks! :)
geposted Wed 05 Nov 14 @ 8:04 am
