I have found two skins designed for VDJ 7 that do not display correctly when opened in VDJ 8.
They are the X-Audio skins by DJ Alex Jarocho.
The main skin graphic (BMP) does not display. Instead the background is just black, with only a few of the skin elements visible. Most (including the settings, min, max and close buttons) are not visible, although they do function if you can locate them.
Why is this? Other skins which use BMP files work fine.
geposted Wed 05 Nov 14 @ 9:45 am
These skins might not work with Virtual DJ 8 Infinity as they may need upgrading for them to work. I suggest that you contact the person who made the skins originally and see what he has to say.
geposted Wed 05 Nov 14 @ 3:49 pm
No, that's not the case.
Skins written for VDJ 7 should work fine in 8 without adjustment. I posted because for some odd reason, these particular ones don't.
The skin author passed away shortly after these skins were completed.
geposted Wed 05 Nov 14 @ 3:54 pm
ive noticed some syntax handling has changed as ive had to edit VirtualTouch (screen swap wasnt working in v8 (swap browser window with deck window))
geposted Wed 05 Nov 14 @ 5:30 pm
