Lustig ;-)
cj-jan wrote :
My little description how to unlock the 2IN2OUT Mode of the DDJ-SX2 without bying the DVS Plugin from Serato on Windows.
open: regedit.exe
go to: Computer\HKEY_CURRENT_USER\Software\Serato\SeratoDJ
change the value of "dvs_plugin_enabled" from "0" to "1"
open Serato DJ -> then the driver will be updated to 2IN2OUT Mode
Now you can run 2 decks with Timecode in VDJ8 with the Pioneer DDJ-SX2
More informations about this and a little Video:
http://deejay-basics.de/2014/11/pioneer-ddj-sx2-dvs-soundkarte-aktivieren/
My feedback now running with build 2028.855, the LED ring in the middle of the jogs does only show up when i load a track to the deck. While playing a track there is nothing moving or light up.
Edit1:
Just checked "get Beta Builds", got 2028.861 and the LED Ring in the middle works like a charm, in the normal mode and 2IN2OUT mode, great work!
Edit2:
i tried a Backspin with the jogs on the DDJ-SX2 and that does not work. It's still set to the default backspin length on the hardware settings (DDJ-SX2 utility menue) as described in the user manual.
open: regedit.exe
Edit1:
Edit2:
geposted Fri 07 Nov 14 @ 9:14 am
LOL :D
Da hat sich aber jemand Mühe gegeben.
geposted Fri 07 Nov 14 @ 9:20 am
